| | | Forums66 Topics128,176 Posts1,057,121 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16436 10/07/2003 5:27 PM | Joined: Apr 2003 Posts: 9 Member | | Member Joined: Apr 2003 Posts: 9 | G'day
Q: Does the 3 speed supply oil to the universal joint simply by being at a slight angle?
My tranny is removed and sitting level at the moment. If tilted it will proceed to spill it's guts. My guess is that the oil is retained by the seal around the propeller shaft inside the torque tube. I'm planning on replacing this seal, however, the stud that is used to retain it cannot be located.
Any words of wisdom?
BIG LIFTER
Tuna is the chicken of the sea Iguana is the chicken of the tree Chicken is the chicken of the three
