| | | Forums66 Topics128,087 Posts1,056,114 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Does anybody know where I can get door wheatherstrip that fits correctly? I've tried 2 different leading brands and the doors won't shut even though they were adjusted correctly before installing the wheatherstrip. I had to put them on backwards to even get the doors to shut.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Steele Rubber Products makes the best quality, accurate repro rubber, some of the vendors carry Steele products, some don't - note that some trucks originally had a weatherstrip that was round, most had one that has a shape like this - the round type can be a problem with fit - adjustment should be done with weatherstrip in place Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Thanks red58, I'll check them out. What I've tried so far had the right shape, but seem to be the wrong density (too stiff) and "pack up" at the front door pillar.
Bill Burmeister | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Bill Read This! I went through this 3 times before I got it right.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
