1 members (Rmillerfly),
59
Mod | | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | Does anyone know of a supplier that makes the strips that screw down around the door (1949 cab) frame on the inside of the cab to hold the rubber weather strip in place. Thanks | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | 52motorhead, if you can't find a supplier for new pcs. call Tom Myers Truck Parts, located in Ok 918 542-3871. I've bought a few things from Tom. Good used parts for a great price. Good Luck http://community.webshots.com/user/46metal | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Might also try Jim Carter Truck parts... | | | | | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | I think those are cab windlace retainers. I've always had good luck buying used from Mother Trucker (Joe Mendola) in AZ.
Never start vast projects with half vast ideas.
| | | | | Joined: Jul 2003 Posts: 31 Junior Member | | Junior Member Joined: Jul 2003 Posts: 31 | Try The Truck Shop - They have the most extensive catalog of parts that I have seen. Truck Shop Catalog See page 40 of above catalog. Truck Shop web page | | |
