| | | Forums66 Topics128,052 Posts1,055,717 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | I can not seem to pull the steering wheel with my puller. Any suggestions? I need to pull the steering wheel so I can remove the cab. Thanks in advance for the help, Wayne | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 |
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | Did you get it off?... I've got a old type puller with a horseshoe shaped afair on it with diffrent sized adapters for these old wheels. But I have heard that a second person applying upward pressure with both forearms and the other tapping on the backed off nut is sometimes all it takes. Good luck.
1941 AK named "PETEY" my buddy.
| | | | | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | I have tried tapping the end of the puller and ended up bending it. The wheel is stuck. Someone has suggested heating it. Thanks to all that have replied. The steering wheel is still not off. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | use heat carefully or you may melt something!! put the puller on, tighten well, spray your choice of penetrating rust loosener around shaft, tap a bit, come back a few hours later and repeat, tighten more, repeat, and repeat and repeat - eventually you'll come back and find it layin on the seat Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I agree with red58. His suggestion does indeed work. Just keep the tension on and keep applying penetrating oil and have patience.
The last resort should be heat - the last resort might get the wheel off but you then might have to find a new wheel (because the old one would be melted and/or distorted). | | | | | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | Thanks everybody for the help. I bought a new puller and pop!! the wheel is off and the column is out. Two more bolts and the cab is off. Thanks again, Wayne | | |
