4 members (TooMany2count, frogfarmer, moparguy, 1 invisible), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#16425 07/02/2004 4:14 AM
V
V Offline
Good day all,
I am currently in need of a steering box as my 3 year old one purchased from NAPA auto is "gear jumping" causing the truck to pull to the right .
It did this from day one as well as leak.My application is a '70 chevy 2wd with power..the one in it now is a quick ratio original equipment but I am less than pleased with it.
I have driven my brothers 4x4 blazer and I must say I do like the ratio of that one..so my questions are two...
#1 Will the 4x4 box fit without mod's?
#2 Which quick ratio after market box would you reccomend that would bolt in with no mod's?
...I prefer to stay as visually original as possible.
TIA.
a state of mind.
#16426 07/02/2004 4:29 AM
V
V Offline
Regarding the 4x4 option, the reason I ask is that he no longer owns the truck, otherwise I would do a visual check.
a state of mind.
#16427 07/02/2004 6:35 PM
4x4 box is another animal, won't fit 2wd. Try a later box(68-87 all fit), I have a variable ratio box from a 81-87 I like really well. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#16428 07/03/2004 5:51 AM
V
V Offline
Appreciate the input Fleetside, I have noted that info.
One would think that more people have actually crossed this road.
I have found these two web sites...
AGR
http://www.agrperformance.com/catalog-products.jspx;jsessionid=5448F099B942BAF0A2ACFD22F8FC2A0C?cat=101
Corvette steering service
http://www.cvsteering.com/gm%20parts2.htm
a state of mind.
#16429 07/03/2004 10:55 PM
Quote
Brian - is that a bolt in change, other than adapter fittings for the hoses. I'm getting ready to redo the box on my 69, it leaks like a sieve.
Fred
52 3600
69 C-10
