2 members (tclederman, Phak1),
37
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16425 07/02/2004 4:14 AM | Joined: Jul 2004 Posts: 10 Member | | Member Joined: Jul 2004 Posts: 10 | Good day all, I am currently in need of a steering box as my 3 year old one purchased from NAPA auto is "gear jumping" causing the truck to pull to the right .
It did this from day one as well as leak.My application is a '70 chevy 2wd with power..the one in it now is a quick ratio original equipment but I am less than pleased with it. I have driven my brothers 4x4 blazer and I must say I do like the ratio of that one..so my questions are two... #1 Will the 4x4 box fit without mod's?
#2 Which quick ratio after market box would you reccomend that would bolt in with no mod's? ...I prefer to stay as visually original as possible. TIA.
a state of mind.
#16426 07/02/2004 4:29 AM | Joined: Jul 2004 Posts: 10 Member | | Member Joined: Jul 2004 Posts: 10 | Regarding the 4x4 option, the reason I ask is that he no longer owns the truck, otherwise I would do a visual check.
a state of mind.
#16427 07/02/2004 6:35 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 4x4 box is another animal, won't fit 2wd. Try a later box(68-87 all fit), I have a variable ratio box from a 81-87 I like really well. Brian | | |
#16428 07/03/2004 5:51 AM | Joined: Jul 2004 Posts: 10 Member | | Member Joined: Jul 2004 Posts: 10 | Appreciate the input Fleetside, I have noted that info. One would think that more people have actually crossed this road. I have found these two web sites... AGR http://www.agrperformance.com/catalog-products.jspx;jsessionid=5448F099B942BAF0A2ACFD22F8FC2A0C?cat=101 Corvette steering service http://www.cvsteering.com/gm%20parts2.htm
a state of mind.
#16429 07/03/2004 10:55 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by 64fleetside: Try a later box(68-87 all fit), I have a variable ratio box from a 81-87 I like really well. Brian Brian - is that a bolt in change, other than adapter fittings for the hoses. I'm getting ready to redo the box on my 69, it leaks like a sieve.
Fred 52 3600 69 C-10
