7 members (Jon G, GMCJammer51, Otto Skorzeny, Greg_H, TUTS 59, 1955 1 Series, Joe H), 162 guests, and 6 robots.
Topics128,078
Posts1,056,044
Members48,433
#16402 04/25/2002 4:17 AM
iam about to take my first carbuerator and would like any hint and tips ya'll might have.
Hudson
#16403 04/25/2002 4:26 AM
Red dot, center of chest ...
Study the parts blowup that comes with the rebuild kit very closely. Make sure you know exactly where each part goes before you start taking it apart. When you take it apart, put like things together. For example, if there's four screws that hold the top on, put those four screws together in one pile. Use a white towel or old white t-shirt to put the parts on and lay them out in an organized fashion so you can find things as you put the carb back together.
Use carb spray and spray all the little passages in the body. Clean the carb really good. And finally, make sure you adjust everything as precisely as you can; float level, float drop, choke rod settings if it has them. Don't lose any of the check balls, and mark down where each one goes.
If you have a friend who's done this before, keep him nearby.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#16404 04/25/2002 4:29 AM
thanks for the help i will da that
#16405 04/25/2002 5:41 AM
and use eye protecion with spray carb cleaner or blowing out the carb with air pressure and avoid to much skin contact with chemical cleaners can't be too safe good luck
i thinkzz traveling along at terminal velocity will soon wear a body out.
i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#16406 04/25/2002 6:38 AM
Anonymous
Unregistered
Anonymous
Unregistered
compare the drawing that comes with the rebuild kit and note any differences as you are taking the carb apart . . . the time to discover your working with something a little different is not when you are trying to match up parts that you have that look nothing like the parts in the picture. You might have to get creative to actually use all the pieces up when putting it back together.
#16407 04/27/2002 3:28 PM
I like to take 'em apart and save the leather pump. Then put 'em into my own 'lil hot tank with hot water and a dash of tsp. Next day pour off the gunk and dry out parts they is clean and ready for rebuild. The tsp is a lot safer and cheaper than the toxic stuff in the spray cansz....
#16408 04/27/2002 3:37 PM
As a newbie at carb repair and just finishing mine yesterday, my tip would be when ever you remove stuff from inside the carb , take the inner nuts and screws off slowly.I found out the hard way that there was a spring in the one and took forever to find that little ball that went a rolling eek .
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#16409 04/27/2002 3:47 PM
Oly Offline
OH- by the way Slow rider, watch out for that little spring with the ball that can get away from you.-LOL There is no substitute for OJT. Glad to hear that you were alert.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
