1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | After rooting through my new shop manual and assembly manual for the '58, I am beginning to think that heaters might have been a dealer install or something because neither references heater stuff.
When the truck was painted, all the controls were unhooked, the controls them selve need a little work, and I likely need a new heater core.
Anybody know where to get some decent info concerning heaters? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have found good info in the accessory install manual for my truck,,Red58 has some info also, might PM him,,he will see this thread I'm sure,,brian | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes the heaters were ALL optional - there were 3 heater versions: the bottom of the line one was only dealer installed,, the middle one was a factory installed 'standard' ["recirculating"] version that had no cables, just a 3 position fan switch, and a factory installed deluxe model w/ the fancy control unit [tho they could also be dealer add-ons] that option stuff is how GM and the dealers made the gravy see the manual here , HEATER & DEFROSTER (DELUXE) - Truck RPO #987641 Bill | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Thanks a TON red. That's exactly what I needed. darn, I have the deluxe, ain't I special..
Now I just gotta find a replacement core.. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | best bet is to find a rad shop that can get the right size core and put the end tanks from yours onto it - possible, but many rad shops can't be bothered, need to find one run by an old timer, but some of the repro suppliers may have them too - they also have cables and all the parts for the control
Bill | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I had my 72 heater recored, and then found out that a new assembly was actually a bit cheaper (not including shipping). So my momma told me...you better shop around!  | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Originally posted by arnswine...: I had my 72 heater recored, and then found out that a new assembly was actually a bit cheaper (not including shipping). so far, the parts store around here only go back to about '62.. I'll be checking on re-cores today.. | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Red, I've seen the recirlator and the delux, what did the cheaper one look like? Also I've seen one that looked more like sometime for a tractor than a truck. It was just a box without a blower. I think it was in a GMC big truck. Got any idea's on this. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Avette, I wouldn't expect the chain stores to have much that old, hafta check around the repro dealers, especially ones that have used parts if you can't find a rad shop to make ya one Jeff, you can just make the cheapie out here , and here - the chrome logo button on it just sez GM, and I think they used it on Chevs and GMCs both for at least part of the AD years until the early 60's - the cover on that one [with fan/motor] came from a dealer dumpster in Victoria BC, thrown out as obsolete in the 80's might be the one you refer to? just a heater core covered with that shroud that contains the fan, but there is one in my stash that's 'boxier' that I haven't really paid much attention to as I have no idea what it's from! Bill | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Originally posted by red58: Avette, I wouldn't expect the chain stores to have much that old, hafta check around the repro dealers, especially ones that have used parts if you can't find a rad shop to make ya one
Bill I figured that but asked em anyway..none..I also kinda had my hopes up that LMC might have one. They have everything but.. Not a big deal, I'm in a small area outside of Oklahoma City and am pretty sure I can get one of the local home boys to rebuild one for me.. Thanks again for your help... | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 |
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | shot 'em an e-mail..thanks! | | |
