0 members (), 129 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
Junior Member
Junior Member
doing some general re-wiring cleaning up under the dash. How important is that brown (very dusty) insulation right up under the dash? Can it be replaced, with neater, cleaner material? Or can it be done away with completely?
jcf
You are probably referring to the firewall cover. Made of insulated cardboard. You could remove it but you'll experience heat and noise from the engine bay and road. ABS plastic or fiberglass replacements are available from vendors. Steer clear of the cheap rubber ones.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
Junior Member
Junior Member
got that, thank you; how about the other isulation way up between the steering column and the dash proper,heating vents, and radio; can that be replaced?
jcf
Not sure on these points as my 59 has only the firewall cover. Am pretty sure if you can't find ready made repro you could accomplish this with a visit to Home Depot tho.
Bruce
usually the custom cab truck got extra stuff glued up above the regular firewall pad. I scraped all of it off & glued down that gray jute pad that is under auto carpet. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Jute material is a good replacement, available at fabric stores that cater to upholstery shops. Maybe even the one sided foil backed insulation material available at auto parts houses. Use 3M spray on glue.
Jim & Caroline
Junior Member
Junior Member
Thank you all, for the great suggestions.
jcf
Moderated by  ndkid275, Phak1
