10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible), 94 guests, and 3 robots.
Topics128,062
Posts1,055,847
Members48,428
#163913 01/27/2006 8:26 PM
Junior Member
Junior Member
I know it's going to sound dumb...but, how the heck do you put the wire that comes with the new replacement back down the cab around the back window to the opening where the gas tank is??!!
jcf
Anonymous
Unregistered
Anonymous
Unregistered
feed a wire coat hanger up from the bottom, tape the wire from the light to it and pull it gently down or do the reverse if the light's wire is not long enough.
If the original light and wire are intact, use the original wire as the "fish" to pull the new wire through!
Stuart
Junior Member
Junior Member
"but of course!" Doh! thanks mucho.
jcf
Moderated by  ndkid275, Phak1
