0 members (),
130
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 42 Junior Member | | Junior Member Joined: Jan 2006 Posts: 42 | I know it's going to sound dumb...but, how the heck do you put the wire that comes with the new replacement back down the cab around the back window to the opening where the gas tank is??!!
jcf
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | feed a wire coat hanger up from the bottom, tape the wire from the light to it and pull it gently down or do the reverse if the light's wire is not long enough. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | If the original light and wire are intact, use the original wire as the "fish" to pull the new wire through!
Stuart | | | | | Joined: Jan 2006 Posts: 42 Junior Member | | Junior Member Joined: Jan 2006 Posts: 42 | "but of course!" Doh! thanks mucho.
jcf
