9 members (jmoore, KEVINSKI, Bucker, 55shaker, 3B, papas52, 2-Ton, Joe H, GMCJammer51), 92 guests, and 2 robots.
Topics128,157
Posts1,056,894
Members48,458
Got brown crinkle paint for my 36 1/2 ton.. but the application with heat from hair dryer seems so much work for that look- is it worth it? Thinking of doing a nice wood grain on dash. I know they didn't offer that in 36 half tons. And was headliner a straight brown or was it wood grained...have read both. Where do you still get fiberboard for this...don't want any fiberglass. thanks.
bruce duykers
I have had bad luck applying wrinkle paint in the winter.
It always seems to work best in July or August.
bruce,
I am going to guess there is a actual difference between "crinkle" and "wrinkle" paint. I have used wrinkle paint quite a bit and it is truly heat activated.
If your crinkle paint needs a elevated temp to activate and crinkle, an array of heat lamps over the surface to be painted works well.
My experience has been that the heat must be VERY uniform, otherwise the effect will not be uniform either! Heat lamps get quite hot, so you could cook the paint if not careful.
Stuart
I'm going to use "hammered" paint on my '54. It hides surfact imperfections and does not provide as shiny of a reflective surface as smooth paint.
Moderated by  ndkid275, Phak1
