| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 61 Member | | Member Joined: Aug 2005 Posts: 61 | Got brown crinkle paint for my 36 1/2 ton.. but the application with heat from hair dryer seems so much work for that look- is it worth it? Thinking of doing a nice wood grain on dash. I know they didn't offer that in 36 half tons. And was headliner a straight brown or was it wood grained...have read both. Where do you still get fiberboard for this...don't want any fiberglass. thanks.
bruce duykers
| | | | | Joined: Sep 2005 Posts: 30 Member | | Member Joined: Sep 2005 Posts: 30 | I have had bad luck applying wrinkle paint in the winter. It always seems to work best in July or August. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bruce,
I am going to guess there is a actual difference between "crinkle" and "wrinkle" paint. I have used wrinkle paint quite a bit and it is truly heat activated.
If your crinkle paint needs a elevated temp to activate and crinkle, an array of heat lamps over the surface to be painted works well.
My experience has been that the heat must be VERY uniform, otherwise the effect will not be uniform either! Heat lamps get quite hot, so you could cook the paint if not careful.
Stuart | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I'm going to use "hammered" paint on my '54. It hides surfact imperfections and does not provide as shiny of a reflective surface as smooth paint. | | |
