| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Does anybody reproduce a floor mat for the AD Suburban? The crispy one I removed from my burb ran under the small flip forward seat. All I can locate is the regular truck mat. Bruce | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Bruce, If the 1955-1st rear floor mat is the same color (black) as the '54's, then I do not think anyone is selling a replacement mat or even correct material (linoleum) for you to make your own. Battleship Linoleum used to have the brown in the correct thickness (brown is the color of rear floor mats in earlier Suburbans). If you can find a sheet of black linoleum (in the correct thickness), you would have to machine/route the grooves into the mat (they can provide an article describing how to do it). Please post a followup here if you contact Battleship Linoleum and if they have the correct thickness of black linoleum (it used to come from Europe but Armstrong? stopped importing it a few years ago). Tim | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | The rear mat was my next question. What I'm looking for right now is the front mat. Bruce | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Bruce,
Sorry I read that so quickly. I have never seen an original or reproduction front floor mat as you describe. Out of interest, I will check the Master Parts Catalog to see if I can find an original part number.
Tim | | | | | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | There's no repro out there. I just got the standard cab mat and added some ribbed floor mat from the HomeDepot (2'x2' does it) under the jump seat it really doesn't affect the look much. The oringinal mats were coco brown anyway and you'll NEVER find that. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If '55-1st has a black rear floor mat, the same color as in 1954, then I bet the front floor mat is black.
The '54-'55-1st upholstery and cardboard door panels were also different colors from earlier years' suburbans.
1929-1954 Chevrolet Master Parts Catalog Section 16.800 (Commercial Vehicles front floor mats)
3810590 1954 Suburban (front floor mat molded under the passenger seat. 3810690 1947-1953 Suburban (front floor mat molded under the passenger seat)
There was also a Suburban front floor mat available that apparently was not molded to go under the passenger seat. 1952-1953 3698175 | | |
