| | | Forums66 Topics128,185 Posts1,057,279 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | Anyone figured out a solution that works as well as the original? Any idea why this piece still isn't reproduced? Or is it, and I've just not found it? I've never had my hands or eyes on an NOS Radio in the box to know what that seal really looks like. I've got two or three complete radios and not a one has a good seal. they're all in various states of disintegration. Any ideas? Thanks!
-Josh
1956 GMC 100 NAPCO Deluxe 1955.1 Chevy 3600 NAPCO 1954 Chevy 3600 NAPCO
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Window air conditioner sealing foam might work well, that's what I used to reproduce the foam seal on my A/C vent,,black spongy stuff. Brian | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Josh, Here is a radio with a foam seal in poor condition. Side View of the same radio. They usually look like this (the knobs are wrong on this one, too). I have never seen a reproduction seal but hope that some else has. 64fleetside's suggestion is a good one. I do not think that it matter is the seal is a little too big; you just wat a seal between the speaker plate and the inside of the grill. Tim | | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | Ha...yeah, Tim..that's exactly what most of mine look like! CRAPPY!! Thanks for that picture of the good one! Did you rig that speaker brace? none of my radios have ever had that... I just spoke with a gentleman in Ohio, and he said what he does for the 54 speaker foam is us a 47-53 and cut it down, because the 54 is narrower...I've never had the need to look at one, but does this seem possible to you? I think I might try it.
-Josh
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I thought Heavy Chevy had that seal bit have not yet ordered one to look at it. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Greg, Thanks. If someone buys this, please let us know if it is the right seal. Page from Heavy Chevy Catalog Part# 765 1954 Radio Speaker Seal Chevy $5.50 Josh, When you asked "Did you rig that speaker brace? none of my radios have ever had that...", were you referring to (1) the plate that the speaker is attached to or (2) the bracket that hold the side of the radio under the dask (I recall that it attached to the side of the radio and part of the cowl air-scoop brace). Tim | | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | Tim,
I was referring to the piece of plate metal that's at a 45 degree angle to your speaker grille...It just dawned on me how massive the magnet is on that speaker...I know my OE speaker didn't have a magnet like that! Is that a repro six volt speaker?
-Josh
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Josh, If you are referring to the brownish sheet that goes from the top of the speaker plate towards the rear of the radio (at a 45 degree downwards angle), that is a cardboard cover that is available from Chevs of the 40s That is a replacement speaker but it is pretty much the same size as an original speaker (maybe the magnet at the rear is a larger). I will check out an original speaker tomorrow. Tim | | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | Tim,
I was referring to the piece of plate metal that's at a 45 degree angle to your speaker grille...It just dawned on me how massive the magnet is on that speaker...I know my OE speaker didn't have a magnet like that! Is that a repro six volt speaker? Anyway, I just ordered a few things from Heavy Chevy, including that sponge seal...I'll be shocked if it's anything like the OE seal for 5 bucks. Might get a pleasant surprise, but I'm not holding my breath! I'll let everyone know how that goes!
Josh
