1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | OK guyz, I have another querrie ... what makes a good flat panel that I can help dress up the back and corners of a cab's interior and cover that foil wrapped heavy duty jute and dynamat with. Probably close to the same ''so called cardboard'' as the ceiling material. It should be fairly big and bendable in the corners and I'd like to cover it w/ matching hyde'o'nyga to match the seats? ANY IDEAS Thanks in advance jim
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
| | | | | Joined: Apr 2001 Posts: 23 Member | | Member Joined: Apr 2001 Posts: 23 | I use mahogany door skins from my local lumber yard. They might flex around the corner with some persuasion........ | | | | | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | I found out that RODDOORS - Chico California @ http://www.roddoors.com/# makes available three different interior packages for your AD's. You can buy any part of/ or what little you want from any of the packages. You're not limited to the whole package deal. The interior panel is moulded ABS, and you can glue any type covering to it to match your interior. HOPE IT HELPS Jim
Gooday Jim
| | | | | Joined: Sep 2003 Posts: 16 Junior Member | | Junior Member Joined: Sep 2003 Posts: 16 | If you want it ready to install, rod doors, if you want to make it your self Home Depot has a fiberglsss ABS panel 4x8 used in bathrooms, I use it interior work. around 30.00 | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | If you want to order the proper water proof panel board go to www.atrim.com/index.html and click on P and look for panel board 32"x48" Good Luck | | |
