Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (3B, TooMany2count, DaveV), 132 guests, and 6 robots.
Topics128,283
Posts1,058,513
Members48,490
OK guyz, I have another querrie ... what makes a good flat panel that I can help dress up the back and corners of a cab's interior and cover that foil wrapped heavy duty jute and dynamat with. Probably close to the same ''so called cardboard'' as the ceiling material. It should be fairly big and bendable in the corners and I'd like to cover it w/ matching hyde'o'nyga to match the seats?
ANY IDEAS
Thanks in advance
jim
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
I use mahogany door skins from my local lumber yard. They might flex around the corner with some persuasion........
I found out
that RODDOORS - Chico California @ http://www.roddoors.com/#
makes available three different interior packages for your AD's. You can buy any part of/ or what little you want from any of the packages. You're not limited to the whole package deal. The interior panel is moulded ABS, and you can glue any type covering to it to match your interior.
HOPE IT HELPS
Jim
Gooday
Jim
Junior Member
Junior Member
If you want it ready to install, rod doors, if you want to make it your self Home Depot has a fiberglsss ABS panel 4x8 used in bathrooms, I use it interior work. around 30.00
If you want to order the proper water proof
panel board go to www.atrim.com/index.html
and click on P and look for panel board 32"x48"
Good Luck
Moderated by  ndkid275, Phak1
