1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 10 New Guy | | New Guy Joined: Feb 2004 Posts: 10 | is there a procedure for removing the steering wheel on my 1951 3100? any help would be appreciated,also tools needed for the job .i want to reuse the wheel. thanks seems to be a bigger job than i thought | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Spent a whole day doing that..Get yourself a steering wheel puller, and a can of PB Blaster..They have it at WalMart..Put on the puller, and tighten down, shoot the stuff on and wait, come back later, tighten down, shoot the stuff on, come back later, tighten down, shoot the stuff on, come back later...Amazing as it might seen, it will come loose..Take your time, and don't beat on the wheel..Good luck, Steve | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i took mine off by loosening the nut and putting my knees under the wheel with upward pressure on edge of wheel and tapping on the nut. came off very easy. maybe i was lucky but it worked. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | I did the same as Ron. Kinda sat Indian style with my feet up on the dash. Just loosened the nut and while prying up, tapped it (pretty hard) with a wooden dowel. Also had to rock it back and forth while pulling. I've never had to use a wheel puller on any steering wheel I've pulled but would use it if these methods didn't work.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | Joined: Mar 2005 Posts: 18 Junior Member | | Junior Member Joined: Mar 2005 Posts: 18 | Most pullers are made to take hammer blows on the pusher bolt. But remember your not trying to bust rocks. Tighten, then a few swats keep repeating this (PB blaster too) it should pop up. | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I pulled the steering wheel off my 54 GMC with one of the cheapo (~$5.00) steering wheel pullers. After removing the center nut and attaching the puller it came right off with no problem.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Long after the steering wheel is off you are going to have the smell of the PB Blaster...use it sparingly with lots of rags, it's very stinky!!
Stuart | | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Most of the major parts houses now let you borrow specialty tools for Free w/Depost. A nice wheel puller could come in handy. Rance Originally posted by cujo8: ... cheapo (~$5.00) steering wheel pullers ...
| | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Originally posted by atomarc: Long after the steering wheel is off you are going to have the smell of the PB Blaster...use it sparingly with lots of rags, it's very stinky!!
Stuart
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the first time I hadta pull a wheel I made this outta what was handy, and it's pulled a dozen since - shouldn't need any lube if it hasn't been in the weather Bill | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Can you all look at this tech tip and let me know if I can update it with some of your information. I'll need to know what to add. (Oh, and I also see I need to fix the image!) Thanks, Peg
~ One of many.
| | | | | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | I made mine in about ten minutes. Using a flat steel strap, 1/4'' x 1'' with rounded corners to fit the horn area, drill two holes so as to allow you to screw down 2 - 5/16''x18, 2-1/2'' bolts into the steering wheel hub. Using the steering wheel threaded post as part B I tightened down the two nuts I have on the bolts. By tightening these nuts and shortening the attaching point, the wheel comes up. I used rustsolve and a wooden handle tap or two. It took two minutes to pull. good luck
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I've had a few that wouldn't budge, then a small amound of pressure from a different angle popped them loose. A Dana 44 front steering knuckle has also pulled that trick on me. | | |
