8 members (KEVINSKI, mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, 1 invisible),
148
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | I have a 66 fleetside longbed chevy truck. In prep. for removing the trans. cover inside the cab, I removed the floor mat, and found some thin foam padding, followed by tar paper under that. What's all this for and is this standard? Thanks in advance.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's the brainchild of the PO, and no it's not standard - originally it woulda had a rotten tar impregnated fibre underlay below the mat that was the primary cause of rotting floors because of the moisture it collected and held - folks here seem to have agreed that a stuff called Peel and Seal is the best modern replacement, but you can get the repro original stuff
Bill | | |
