Brrrr
place holder
2 members (Peggy M, MTD91), 141 guests, and 0 robots.
Topics128,274
Posts1,058,432
Members48,489
#163119 06/12/2005 5:03 PM
I'm ready to put floor insulation/soundproofing in my 1953 GMC and reviewed many previous posts but I'd like to get your experiences on whether you put the soundproofing (peal & seal) down first then then foil backed jute or the other way around. Your experience will help alot. :confused:
#163120 06/12/2005 8:06 PM
I put the peal and seal down first, but I used double layer bubble wrap with foil on both sides. Figure if water ever does get in or you blow a heater core. it won't soak water like the jute stuff would. Also it is lighter and it has a good R rating. Have a look here.
http://photos.yahoo.com/sublime589
#163121 06/20/2005 5:18 PM
I just finished my truck this weekend. I put down the heat shield, it is actually the double foil backed insulation that goes around a water heater. Then I put the jute padding down. WOW what a difference it made, it was unbelievable. Took me about 3 hours. I put a few strips of jute padding glued in the inside of the doors and quieted them up quite a bit.
Well worth the time and effort. Still need to do the roof though.
Good luck,
Chris
Chris 1955FirstSeries
#163122 06/26/2005 12:35 AM
After painting the entire floor with POR-15 we used some rubber roof patch material from Home Depot as a vibration barrier. I cannot recall the name of it but it comes in a 6" x 12' roll for under $15. Not as fancy or quite as thick as the big league stereo stuff but works very well. Next we sprayed StickyStuff and used the double sided foil backed The Insulator. About $20 for a 4'x6' roll. Finally we put in a new rubber carpet and this thing is tight, dry and quite. Whole job was under $140 and we had enough to put it under the seat and behind the gas tank. Personally I don't think anybody has a better interior than we have but almost everyone has spent a lot more. I credit my wife with a lot of the cut and fit labor and why it looks so good. We also used the Insulator under the original style headliner so this thing is warm too.
I should also mention that I got the tip on the roof patch stuff from Horvath, thanks Alan.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Moderated by  ndkid275, Phak1
