1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | The steering wheel on my 56 gets sticky and black residue gets on your hands when the weather is damp... but after driving it a bit the wheel polishes up again and the stickiness and residue goes away. Anyone else have a problem like this?? Any ideas on how to fix it?? Thanks! | | | | | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | I got the same problem. And I need the solution. Leather cover?? | | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | The short answer is to prep and paint the steering wheel fellas. A longer answer is here: Spifin\' up the Steering Wheel | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Always enjoy your detailed notes about your progress with BillyBob!
But I'm not sure I want to got he painting the steering wheel route. I'm not convinced that paint will stand up to the use. Especially with no power steering! Hell, I already broke a 'suicide knob' I had on the wheel!
I think I'll try some heavy duty cleaning on the wheeel today.... | | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | Thanx Larry. I think conventional wisdom is that the stickyness comes from the plastic that the wheel is made from and that certain climatic conditions causes it to break down. There's nothin' scientific about conventional wisdom, however, and your mileage may vary. Cleaning may do the trick. After decades of frustrating computer work, I've learned to avoid stating absolutes . . . Nebber say nebber. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | You're right Larry, nebber say nebber! But then again I try to stay far, far away from computers... as a creative type, my brain just can't work in that linear a fashion!
I used brake cleaner on the wheel today and took off lots of gunk. But the jury's still out... will report back after the next wet weather day, which here in New England may be any moment now.
thanks for your advice meanwhile! | | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | I had the same problem with the wheel on my 52. I bought a steering wheel puller and popped the wheel off. Then scrubbed it really well with a strong cleaner (I used about 1/4 cup of TSP in a gallon of hot water. Spic and Span is the same thing). After about twenty minutes the water was turning light gray instead of black. After letting it dry really well, I spray painted it with a couple coats of clear lacquer. That was last spring, and 3000 miles ago. It's still doing the job - No more dirty hands on humid mornings.
My dad always told me, "Don't force it, get a bigger hammer".
| | | | | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | I was under the impression that the wheel was factory painted.
Was I mistaken? | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I'd presume so Train... on my wheel I can still see traces of black paint where there is less hand contact. But on the overused surfaces the paint is long gone. So far over the past two days I'm not getting any residue. My 56 is my daily driver so it's annoying to have it happen.
I'm still leary about painting the wheel tho. But I do think I'll get out some black two-part epxoy and fill the cracks... | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | The paint idea will take care of the problem. The secret is in what KIND of paint you use. I'd use polyurethane paint the color you want,and follow with a few coats of clear polyurethane.Itll be gas and oil resistant and it'll outlast the rest of the truck,uh,well,ALMOST,anyway. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | You can get appliance epoxy in rattle cans at Ace in various colors. I tried some on a headlight knob, it seems to be hard as a rock. Yes, paint will wear through again - probably in about 20 years, just like the original. BTW, those steering wheels aren't plastic. They're a very hard rubber material. Trust me, you can tell a plastic steering wheel - they crack into a zillion pieces. | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | i have mine covered in the leather wrap stuff but i had to splice two of them together since the steering wheels are so much bigger than the modern day wheels. doesn't solve the problem but does keep the hands clean!
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
