0 members (),
104
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | This is regarding the rubber around the perimeter of the doors. I believe it is called the cab windlace, but it fits in the track that is around the door frame. How do you get it to go in? I can run it part way, but it seems to bind up and will not pull further. I have made sure the track is not pinching. Something I should use to lubricate the path? Don't think I should use a oil based product. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | DO NOT USE OIL BASED PRODUCTS!!!! Use really saopy water mix. If you do a search here on the stovebolt, you should be able to find a long winded post on it from ,,, early last year?? :confused: Somewhere back there anyway
| | | | | Joined: May 2001 Posts: 9 Junior Member | | Junior Member Joined: May 2001 Posts: 9 | the magic elixir for putting cab windlace is Armor-all or STP Son of a Gun...
Spray the windlace and the tracks with either, get the stuff started, and it should slide right in.
Either of the above is slippery, water-based, and won't hurt rubber. Even if the track for your windlace is rusty or dented, this will probably work. | | |
