1 members (NJC),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16280 09/08/2003 9:11 PM | Joined: Aug 2003 Posts: 5 Junior Member | | Junior Member Joined: Aug 2003 Posts: 5 | Does anyone know of a conversion kit do adapt a standard spin on oil filter so I can get rid of the cartridge filter rig on my 62 C10?? I know someone used to make these.
Counterguy
#16281 09/08/2003 11:13 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Just about every FLAPS has one of those on the shelf.
#16282 09/11/2003 2:10 AM | Joined: Aug 2003 Posts: 11 Member | | Member Joined: Aug 2003 Posts: 11 | You can try www.speedwaymotors.com I've seen them there for around $15.00
1964 Chevy C-10
#16283 09/12/2003 8:24 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | When looking at the remote filter parts, there are a few variables to consider:
1. Remote filter head: do you want to use 3/16"x16 (Chevy) vs 3/4"x16 (Fxxd) filters
2. Where will you mount the remote head (firewall or somewhere on the block). This choice will determine if you need a additional mounting bracket (fabricated by you).
3. The length of hoses needed is dependent on where you mount the remote head.
4. Hose fittings and possibly adapters for both ends of the hose (into the block and into the remote head).
The speedway motors site listed above has prices around $18 for the remote head and $25-$30 for ends/hoses. I have seen complete kits at Pep Boys for $25-$30 (hose, ends, and head).
Good luck, Tim | | |
#16285 09/13/2003 1:36 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might be able to find a cheaper kit if you do not need a block-off-plate (you do not need one for a '58-'62 261).
By the way. Is there any problem using a remote remote spin-off filter with a 235 or 261 engine that is set up for a bypass (rather than a full flow) filter?
Tim | | |
#16286 09/13/2003 4:14 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The only problem is that a spin on oil filter doesn't have the restriction that the cannister filter does for the bypass filter, so you need to add one to keep the engine from loosing oil pressure. Someone can chime in with the restriction size; my 261 has the full flow setup.
