2 members (3B, 1955 1 Series),
36
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 43 Junior Member | | Junior Member Joined: Feb 2003 Posts: 43 | Hey all! Does anyone know if the window seals sold separately fit better than those sold together in a set,(specifically those for a 1959)? I am refering to the seal that sits at the bottom of window when the window is all the way up (often refered to as cats wiskers). Thanks once again for the help.
rebuild not replace
| | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | I'm bringing this back up to the top because I'm in the process of doing this project on my 49. The window channel had a corrugated metal track with about 6 spring clips. It went all the way around the window opening and down into the body of the door. Are these necessary with the replacement window channels? The cat whisker was missing on my truck but there are some staple holes in the interior garnish moulding and the assembly manual seems to show the cat whisker stapled to this surround moulding. How do you staple this and don't the staples scratch the glass. Would appreciate any input from someone who has done this. Thanks | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Here's my Install on a 54.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Bob - I think you'll find the felts are the same in the sets as those sold seperately - the real "seal" is a rubber piece that fits in the bottom glass channel and has a flange that comes up against the metal at bottom of opening [it's the piece the glass sits in]
Bill | | | | | Joined: Feb 2003 Posts: 43 Junior Member | | Junior Member Joined: Feb 2003 Posts: 43 | hey squeeze the problem I have is that when it is snapped in place the chrome stip at the top is below the edge of the window. I just wanted it to be level with the top edge of the door.
rebuild not replace
