| | | Forums66 Topics128,084 Posts1,056,083 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | wow, when did that happen, nice change (forum moved from the bottom of the list) :p
BrianK
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
| | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | I agree--It's right on the main drag, so I trip over it every time I visit! | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | I think I still have the "suggestion" from one of the 'Bolters to even set up the Interior forum. It was a good idea but the timing was bad. So the best we could do at the time was to just "stick it on there." It is good to have an interior forum. There has been a lot of good exchanges. The moderators are going to move theads to where they belong in the forums. Probably not 100% (that's insane) but generally so. That way if you're looking for something, you'll look in the right place ... or at least start getting in the habit of doing that. So git that oil filter outta the kitchen, yew! Peg
~ One of many.
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | This is a GREAT change! Maybe the INTERIOR Section will finally start getting some attention ... it's already started to.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2000 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 41 | Actually didn't mind having the site sort of off the beaten path. People actually tend to stick to the topic. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | But nearly NO ONE was posting at all before ... now we have some posts brewing!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Gee, Did we have Interior before ?? This is nice ! It will help prevent interior issues from being posted in the cab/body section.
Let's see......where do I start..
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Does anyone know how the interior panels on a 49 burb are supposed to look. The doors seem to be self explanatory but the other interior panels on mine are missing or maybe there werent any to start with. It looks like maybe there was some panels under each window at least there are some screw holes there that did something. Any help would be truly appreciated. This site is the most! | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Weeds
Get some cardboard or posterboard and start making your own templates for panels. Use the templates to cut up 1/8" plywood, cover 'em and install 'em.
A lot of guys are using 1/8" plastic sheets now -- you can form and shape them with a heat gun, then upholster them.
