| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 19 Junior Member | | Junior Member Joined: Nov 2004 Posts: 19 | I've got a '66 C-10, and I've rebuilt the door hinges, and replaced the door bumpers and rubber. The doors and latch-strikers are aligned correctly, but when I slam the door I have to do it hard, and it makes a tremendous BANG! Hurts my ears!
Would replacing the door latch mechanism change this? A friend of mine has a '55 Ford, and it latches with barely a 'click.'
Thanks!
---Scoob, Tucson | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Scoob - usually that effect is from the new weatherstripping holding the door so tight - try adjusting the door outward just slightly at both the latch and hinge sides - also open a window a bit, as the Chev cabs are more airtight than them ol Fords Bill | | | | | Joined: Nov 2004 Posts: 19 Junior Member | | Junior Member Joined: Nov 2004 Posts: 19 | Thanks Bill. I'll give that a go - if I can without totally messing up the door alignment!
---Mark | | |
