1 members (baldeagle),
70
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 16 Junior Member | | Junior Member Joined: May 2004 Posts: 16 | Does anyone have a paint code for the interior color for a 50 pickup? The exterior is Forrester Green and I plan to go back to it, but not seen much about the color of the interior. Looks like a light metallic brown. Would the floor boards under the mats and kick panels be the same color? | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Stevec, the paint you are looking for is called "Champagne". It is available from Jim Carter www.oldchevytrucks.com or Chevy Duty www.chevyduty.com.
Winona 1949 3100 5 Window Deluxe Cab
| | | | | Joined: Jul 2001 Posts: 19 Junior Member | | Junior Member Joined: Jul 2001 Posts: 19 | Does anyone have a PPG paint code for champagne? I would like to purchase the interior paint locally and need a paint code for champagne.
Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brad,
PPG's Color Library was very helpful with 1954 paint codes. The following phone numbers are 6-7 years old. If you call them, would you please post here if the numbers still work or not?
440-572-6100 PPG Color Library - had old paint codes 440-572-6111 PPG Tech Services Refinish (gave me the number for the Color Library)
440-572-6871 FAX number for the PPG Color Library
Good luck, Tim | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Stevec,
Let me know if you find a modern ppg formula for Forester Green. The commonly known one (I think it's 40319 or something like that) is for at best acrylic enamel. I'd like to use DBC or DBU, but couldn't track down a formula.
I gave up on the interior code, as they are just a guess for anything above acrylic enamel. Jim Carter I think is selling lacquer, where Chevy Duty has it in acrylic enamel. I'll irritate my old school friends and say no thanks to lacquer.
Good luck! | | | | | Joined: May 2004 Posts: 16 Junior Member | | Junior Member Joined: May 2004 Posts: 16 | I've got a PPG #40519 and a DuPont #93-62006 as the Forrester Green Codes. I got the codes from a link from here. The interior colors from Chevy Duty are lacquer, but I'm not sure I can handle it with my equipment. May have to try. | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Stevec,
That's the one I was trying to tell you about. It's for old formulas, not DBC or DBU, so no base/clear paint job with that one. Maybe by calling the PPG number would produce a proper code.
Do you want to try it or should I? | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Modern paint formulas for Champagne: PPG 3613 DDL3613 DuPont C8306
Steering wheel, coulmn and shifter: DuPont 8540
| | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | 49erGAL,
Have you (or anyone else) seen this formula in use? It does translate to all modern PPG formulas, DCC, DBU, DBC, etc. Sounds great. Just wondering how it looks...
Thanks for sharing!!!! | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Steve: I haven't gotten far enough to paint the interior yet. I did some local research to find these numbers.
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I had some PPG 3613 made up, but it did not match original cab color, at least in my research. I ended up purchasing interior color for my 49 from Chevy Duty. It was a perfect match in my eyes. Also CD sells it in enamel. Jim Carter's is lacquer. While the original paint was probably lacquer (someone correct me if I am wrong), I preferred to use enamel. | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | How bad was it? Too dark, too light; what was the problem?
When you used the enamel from C-D, did you have to mix it or use it straight from the can? What size orifice did your gun have? I've got a 2.0 and a 1.4, which would you suggest?
Thanks for sharing the info. I almost had a batch of the other stuff made up. I guess I would have lived with it, but I'm glad you said something. | | |
