| | | Forums66 Topics128,087 Posts1,056,112 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 62 | I've been working on the seat adjusters from my '53 3100. They're in great shape except for the fact that they don't move smoothly or allow for the full range of motion. I'd like to disassemble, clean and lubericate them but don't see how. The Chevrolet shop manual talks about removing the entire assemblies but that's as far as it goes. Is there any way to separate the upper and lower channels? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have just been working on mine and I am positive that they are not made to take apart. I used a product called Fluid Film to loosen it up and it did wonders. From what I could see, there are two sets of ball bearings on the sides and inside the vertical load is taken up by wheels about 1" around and 1/2" wide. There is one at the front and one at the back. | | | | | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | Okay, gang, I need to remove my 54 bench seat so that I can install carpet and seat belts. Any ideas on where I can get instructions. I understand that once out it is hard to re-install.
Thanks!!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
