1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 15 Member | | Member Joined: Mar 2001 Posts: 15 | My question: How does the glove box install in the 1950 Chevy PU?
Do you push the box all the way through the opening and then wrap the box around the lip of the opening (the glove box edges will not be seen) or do you push the box into the opening up to where the edge of the glove box is flush with the opeing and then attach the screws (the edge of the box will be visible)?
My after-market box does not seem large enough to wrap around the lip.
Thanks! | | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | Mine has a band of steel that goes around the lip ... which hides the bare edge of the glove box. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, RM
I installed a Re-Pops glovebox in my 54 ... I pushed it all the way in, past the opening, and then wrapped the lip around the opening -- the glovebox edges are not seen. It fit easy enough ... had to collapse it a bit to get it all the way through.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
