| | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | I started installing my Chevy Duty headliner in my 49 AD tonight. Front piece went in fine as did the center channel. The rear piece lines up correctly in the back but is about 1-1/2" short of making it to the center channel. I'm wondering if CD sent me a headliner for the pre 49 floating type or is it just cut wrong? | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Wouldn't suprise me if you got the right parts but the parts were cut to the wrong size. With my 55.1 headliner with the floating bar the sides were 1/4 ti 1/2 inch off leaveing a gap in the rear corners and front corners between the headliner and the weather stripping.
-Chris
Chris 1955FirstSeries
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | same problem.I think they were cut short by some joker.everyone Ive seen were short
dan-pa
