4 members (Rick Brown, Bill Hanlon, 2-Ton, 5 Window 9434), 198 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
Does anyone use these items in a brake rebuild? Where did you get them? grin
Are you referring to the Tinnerman nuts that hold the drums on? They are manufacturing aids, to keep the drums in place while the rear ends are shipped to the assembly plant.
Unless you're planning to drive the truck without the wheels in place, grin grin grin they're not needed. Take 'em off and toss 'em.
Brake drum gaskets? Dunno. Never heard of 'em.
Joe
I think they are kinda like muffler bearings. grin
Brake drum gaskets. Are these the thin gaskets that are put in place on the rear axles and then you install the rear drums? I just recently installed these when I rebuilt my (my trucks) rear end.
Craig
There was a paper gasket there when I pulled my rear drums. About as thick as wax paper. The only thing I could figure was that it was intended to keep the drum from rusting to the axle. I guess this is something you have to make?
No, you can buy them from Chevs of the 40's. It's their part # 365673BC 29-57 (gasket-brake drum (6 lug).
Craig
