1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Now that I'm at this stage I find out that none of the suppliers carry the "delux" headliner material (JC and Chevy Duty have the door panels in this faux leather finish,called deep Spanish grain,though). Any thoughts for doing this right? I can have upolsterer apply a thin vinyl or maybe I'll cover with a wall paper in close like finish. I'm worried that bending the material after it has glue and covering material on it will be a real problem as from posts it seem that just the cardboard can be very difficult to work with.
Jim Carter should be able to help you.
www.oldchevytrucks.com
I don't think the headliner ever came in the faux leather finish. Only the side panels and seat match, not the headliner. That is if your trying to do a factory restoration. Cecil......
I had my headliner in my 46 done. The apolsterer cut new cardboard from the old panels and covered it with a foam headliner material with a finish on the outside. Look here
http://pg.photos.yahoo.com/ph/sublime589/album?.dir=4e07&.src=ph&store=&prodid=&.done=http%3a//pg.photos.yahoo.com/ph/sublime589/my_photos
I'd suggest you consider a one piece fiberglass headliner...has the the same grain as the panels, they're easy to instsall and you can paint/dye them any color you want.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
Quote
The material pulled from the restoration is definately faux leather finish. This is a suburban, maybe they where a tad fancier.
Ohhhhhh, eek I really blew that one. Where can I hide. Cecil.......
Moderated by  ndkid275, Phak1
