| | | Forums66 Topics128,152 Posts1,057,011 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 13 Junior Member | | Junior Member Joined: Aug 2000 Posts: 13 | Getting ready to install a three speed with overdrive in my "59" Apache. The bell housing is set up with two dowels and two bolts but I see that the bottom of the overdrive unit has two 7/16" bolt holes for a crossmember. The rub is that I don't have a crossmember in my truck. What gives? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | those little ears w/ holes are for other applications - the OD trans just hangs off the bell housing like the regular trans
Bill | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | i have a overdrive in a 67 chevelle what it dose is the gearing stays the same but when you let off the gas its like pushing the clutch in and you coast then when you give it the gas it grabs and you go saving gas all other overdrives ive seen were a higher gear this one took me a while to figure out it was a 600. option in 1967 on a chevelle 300 | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | 32fire Does not sound like your overdrive is working. This page will tell you how it should work and how to repair it. Use the back button at the bottom of the page for more info. Borg Warner overdrive '67 should have a full syncro 3spd Saginaw. If you can locate a 4spd Saginaw, that OD unit will bolt to the back of it with very few modifications. That will give you 8 forward gears instead of the 6 you should now have. The 4spd looks just like the 3spd, but it has three shift arms on the side cover instead of two. Overdrive
'67 GMC 3/4 292 4spd
#1621 08/19/2004 12:40 AM | Joined: Aug 2000 Posts: 13 Junior Member | | Junior Member Joined: Aug 2000 Posts: 13 | Squeeze (Bill); Thanks for the feedback on the o-drive installation. Now I can sleep. | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | mine seems to work fine its in a car not truck mayby when its in hi its geared higher but it dose free wheel when you let of the gas i think a 4 spd would be better but im keeping it stock thanks for the info page | | |
