3 members (Gdads51, baldeagle, 3B), 98 guests, and 6 robots.
Topics128,014
Posts1,055,328
Members48,419
#161580 09/19/2003 1:42 PM
Ok Guys, seeing tomorrow is our last golf tournament and I'm retiring as a coach it's time to get back to my truck.
While I'm trying to build the "kitty" to buy my front disc brake system I will be in the process of working on the cab. The cab is on a roller so I thought I would tip it over and work on the bottom of the cab. Question is: Once everything is fixed, cleaned, primed do I PAINT THE BOTTOM SAME COLOR AS THE TRUCK WILL BE OR DO I PAINT IT BLACK TO MATCH FRAME AND THEN ADD UNDERCOAT? Help: WHAT HAVE YOU GUYS DONE!!!
popcorn The Truth is Out There (My brain hurts)
ps: squeeze I had my blood and kidney functions checked I'm Ok just watch my diet. Ben
#161581 09/19/2003 1:46 PM
Anonymous
Unregistered
Anonymous
Unregistered
If you are going for originality . . . I have no idea what color to use, by the looks of the trucks I have had I think they used a cheezy primer or relied on overspray from the body color that weathered and rusted away long before I ever got the truck.
I would think that body color would look the best and that is what I am planning on my rig. Undercoat over that?
#161582 09/20/2003 2:54 AM
To preserve it, I would do just what Ken states he is doing. (Paint body color and then undercoating)
#161583 09/20/2003 2:56 PM
I agree. Paint it black, do not worry much about body color overspray, and then undercoat. If you have an Advance Design truck, the Factory Assembly Manual shows where the undercoat was supposed to be applied (I doubt if it was always applied in the places indicated in the manual).
Tim
#161584 09/21/2003 3:00 AM
Thanks guys!!! popcorn The Truth is Out There (Everybody have a good weekend) smile
1 Offline
piant it the color of the cab.
John A Young
1gr84d8 #411656 05/10/2008 6:16 PM
the floor would be the cab colour, things like inside door panels and dash would be different colour
Keith and Kim
1942 Chev 3/4-Ton Flatdeck in the Gallery
Victoria, BC, Canada
Workinonit #440540 08/11/2008 3:12 AM
My factory assy manuel 55-59 says use 88oz of "underbody protective coating" GM part number 3686683. It also tells where to start and which way to go. Should have a 1/16" thickness after it dries.
Nonething said about Paint color
source: section 1 sheet 139 factory assy manuel.
hope it helps
Brad
brsdb3381 #440564 08/11/2008 3:54 AM
geez, I wonder if pop corn has been holding off painting the cab the last 5 years waiting for you guys to straighten him out? grin
Moderated by  ndkid275, Phak1
