Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
I’m considering lowering my ‘54 2-3”. I understand that I can lower the rear by swapping the location of the springs but I wonder if that upsets the geometry of the torque tube diff to the tranny. Also, what’s the easiest, cheapest way to lower the front using the stock axle AND put in disc brakes using original wheels? Brian
Lowering the rear won't really affect the u-joint much. It will reduce the angle. You don't want it completely straight (although that may only apply to u-joints with needle bearing cups) but it'll probably be a couple degrees. You should loosen the pivot bolts on the spring mounts until you have it setting where you want it and then tighten those to normalize the rubber bushings in them. Can't really say about the front axle short of new flatter springs if you're using the stock axle.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Any kind of lowering method involving using the stock axle will severely limit the suspension travel. The vehicle will bottom out on bumps. The simplest (and most expensive) option will be a dropped axle. Jerry
On looking at pics of my truck (which should be similar to your 54), I don't think changing the location of the springs in relation to the rear axle will help much, as the springs are already under the axle tube.
Brian, I put lowering springs all around my truck. Hot Rod Lincoln is right it does bottom out in the front only. I like the look of the slightly lowered stance. I did have to make a new leaf spring shackle to raise the back 1” as my wider tires slightly rubbed my fenders.
I have a 4 inch drop axle on my '59. The axle is one of Nostalgia Sids, he does really quality work. If I were to do it?again I wouldn't use as deep a drop, 4 inches puts the axle pretty close to the pavement. I currently have 15 inch wheels and tires.
~ Craig 1958 Viking 4400 "The Book of Thor" Read the story in the DITY 1960 Chevrolet C10 "A Family Heirloom" Follow the story in the DITY Gallery '59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
