Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (55shaker, mick53), 160 guests, and 4 robots.
Topics128,286
Posts1,058,659
Members48,493
#1615515 11/17/2026 8:18 PM
O Online: Content
A friend of mine is considering a 1952 GMC 1/2 ton long bed for sale here in Georgia.
It's a stalled project but mostly put together and complete with no rust. (We'll see about that if we go look at it this weekend)
Anyway, I just wanted some opinions or insight on the long bed aspect of this truck. Since Chevy didn't make a 1/2 ton LB, does this make the GMC 1/2 ton LB more desirable? I know that short beds are usually preferred by collectors/restorers/whatever on 60s and 70s trucks but was wondering about the AD trucks.
I personally like the look of the long bed ADs and I like the side mount spare tire.
The truck has a 1951 Chevy 216 in it instead of the GMC engine. Does this make it less valuable or desirable?
Any thoughts or opinions on this vehicle?
1950 Chevrolet 3100 (Ol' Roy)
Thoughts or opinions on this vehicle from a 1952 GMC long wheelbase owner:
I'd say it depends on if he plans to use it as a truck (LWB is better) or a toy (SWB looks better except for the rear wheels not being centered in the fenders). Also, does the extra 10 inches or so create a storage problem?
I'm a fan of the GMC engine for longevity and a little more power. My 228 had unknown mileage on it when I bought it almost 14 years ago. Since then I've put over 42,000 miles on it with no internal engine problems. Carries 55 PSI oil pressure at 50 MPH and idles at about 20 PSI at 450 RPM hot.
That said, the Chevy engine is probably easier to find parts for.
The Chevy motor in GMC may be Canadian.
If the truck is intended as driver as opposed to a work truck I would consider the short wheelbase to be more desirable. I have a fried who drives an early 50’s lwb ; he has commented on the challenges/ limitations in maneuvering space.
In my opinion the short truck is better looking. Purely subjective , but also reflected in the market as I believe the short wheelbase commands a higher value.
Now , if a fellow prefers to longer truck and it is more affordable , he’s all set.
