Thoughts or opinions on this vehicle from a 1952 GMC long wheelbase owner:
Since Chevy didn't make a 1/2 ton LB, does this make the GMC 1/2 ton LB more desirable? I know that short beds are usually preferred by collectors/restorers/whatever on 60s and 70s trucks but was wondering about the AD trucks.
I personally like the look of the long bed ADs and I like the side mount spare tire.
I'd say it depends on if he plans to use it as a truck (LWB is better) or a toy (SWB looks better except for the rear wheels not being centered in the fenders). Also, does the extra 10 inches or so create a storage problem?
The truck has a 1951 Chevy 216 in it instead of the GMC engine. Does this make it less valuable or desirable?
I'm a fan of the GMC engine for longevity and a little more power. My 228 had unknown mileage on it when I bought it almost 14 years ago. Since then I've put over 42,000 miles on it with no internal engine problems. Carries 55 PSI oil pressure at 50 MPH and idles at about 20 PSI at 450 RPM hot.
That said, the Chevy engine is probably easier to find parts for.
