Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (54farmtruck, Wayne67vert, Bill Hanlon, 1 invisible), 166 guests, and 2 robots.
Topics128,299
Posts1,058,705
Members48,493
#1615518 11/17/2026 9:36 PM
Hi guys.
It's been quite a while since I last posted here. Been busy with many other projects.
Today I picked up a roofing screw in the front tire of my 1942 Chevy 3/4 ton truck. First flat I've had in more than 20 years of ownership.
I'm wondering if it may not be time to replace all my older bias ply tires, which are mounted on OE 1942 rims. I did dispose of the split rims on the rear of the truck when I bought it, back in 2004. So all OE rims are now the one piece variety of Chevy artillery wheels.
My question is; Has anyone run tubeless radials on these OE artillery wheels ? If so, do your wheels hold the air pressure without leak down ? Also, if the wheels are not capable of or not safe to run tubeless, is it possible to run them with tubes in the radials? I have no experience with tubes in radials, but I've been told it can be done.
As I'm not someone who likes to spend money first, and ask questions later ... any advice based on first hand knowledge will be appreciated. Thanks in advance.
Ghost Rider
Little Egg Harbor, NJ
1942 Chevy 3/4 ton pickup, 1962 235, Clifford Intake, Custom Headers, 1984 T5, GM T55 Pumpkin
1956 Chevy 3100 Apache, 67 350SBC, Saginaw 4 speed, 69 12 bolt
1939 Chevy Master DeLuxe Sedan (project)
1936 Packard 120 Business Coupe (AACA 1st Place, Junior)
I don’t have the artillery rims, but I did put radials on my stock 16” rims. I have not noticed any air loss without tubes.
