Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Jon G, 78buckshot), 87 guests, and 1 robot.
Topics128,279
Posts1,058,593
Members48,492
I have taken one side of my rocker assembly apart for cleaning. All except the middle stand (the part the bolt goes through to attatch the rocker assembly to the head). It will not budge. Any recomendations?
Thank You
chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Heat and a dead blow hammer. Inspect the bottom of the shafts for wear. It's possible to turn the shafts upside down and drill new oil holes with a solid carbide drill bit. Plug the upper holes with short pieces of round brass rod, tapered to be a snug fit in the holes with a drill press and a file.
O Online: Content
Are you saying you can't loosen the bolt? Try tightening it slightly and then try to loosen it. Use a long breaker bar or pipe slipped over the ratchet handle. Is the head still on the engine and covered in oil or is it bone dry and sludged up?
1950 Chevrolet 3100 (Ol' Roy)
AD Addict & Tinkerer
P Online: Content
You might try an impact hammer. I wouldn’t hit it hard (you don’t want to snap it off), but a few impacts might encourage it loose.
Phil
Project Journals
Stovebolt Gallery Forum
Please describe your problem a little more clearly. Is the bolt refusing to turn, or is the rocker shaft stand stuck on the shaft? Worst case scenario- - - - -use a cutoff wheel or a hacksaw to cut the head off the bolt. Then use vise grips or a stud puller to remove the rest of the bolt, after heating it.
Sorry about the inadequate description.
I have attatched a photo.
The rocker support is stuck on the rocker arm shaft.
I was going to run a screwdriver through one of the bolt holes on the shaft then secure the screwdriver in a vice to keep the rocker arm shaft stationary while I twist the support.
But thought I would ask for advice first.
Chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
O Online: Content
Soak it in a 50/50 mix of acetone and ATF to loosen it it up (better than PB blaster). Your method isn't a bad idea. Find a pipe to slip over the pylon to get better leverage. If the shaft isn't worn out and is still usable, getting the pylon off the shaft isn't a requirement to clean everything.
Thanks Otto.
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Heat from a Propane torch and penetrating oil is your friend. The torch won't get anything hot enough to damage the metal, and a few taps with a dead blow mallet will get it moving. Concentrate the flame on the standoff and the hole will expand faster than the shaft.
Thanks Jerry.
I will do that before I use force.
Chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Are you planning on reusing the shaft? (It looks like it has some wear, but might not be enough to worry about)
Lots of excellent suggestions here. It’s remarkable what a little bit of heat will do.
That said, if you are reusing the shaft, you could just opt to leave it be and clean in place.
Side note: Unless the top end was exposed to some weather or such without a valve cover….thats an odd place for one to stick. Makes me wonder if it’s some sort of petrified oily schmutz rather than corrosion.
1951 3100
JW51,
There was between 1/8 and 1/4 of caked on oil when I took it off the head so it’s probably smutz. Once I get it cleaned I will inspect and see if it's reusable.
Its interesting the amount of wear on the rockers. The six I have removed so far, range from severly worn to perfectly smooth. Of course smooth doesn't mean there’s no wear. I’m guessing some of the valves were not rotating. I have read several posts on resurfacing them myself. I will attempt it on the worst one.
chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
