7 members (SWEET, Donf, rfs56trk, sron48, 78buckshot, Wickedbass, JW51),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16152 04/13/2005 1:50 PM | Joined: Mar 2005 Posts: 12 Junior Member | | Junior Member Joined: Mar 2005 Posts: 12 | I have a '54 Chevy 3100 with a 235. The block casting number is 3769716. The numbers on the pad behind the starter are F13 1. The numbers on the pad behind the distributor are F0911A. It has hydraulic lifters, so I presume it is a car engine. Can someone tell me what year it is?
Thanks!
Doug 54 Chevy 3100
#16153 04/13/2005 5:02 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Looks like a '61 to me. F 13 1=June 13, 1961. With it being a car engine, it probably has a fiber cam gear too. If you are planning on having it apart soon, I would recommend replacing the timing set and upgrading the cam gear to an aluminum one.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#16154 04/13/2005 6:05 PM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Unfortunately, Chevy stopped using a year designation in the engine serial numbers in '57, so one has to go by the casting date on the block. I would say fab51 is correct about the casting date. In addition, the serial number gives the assembly plant (F=Flint), month and day that the engine was assembled (09/11), and the "A" suffix confirms it as the standard car 235.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#16155 04/13/2005 6:10 PM | Joined: Mar 2005 Posts: 12 Junior Member | | Junior Member Joined: Mar 2005 Posts: 12 | Tim
Thanks for the info. It's running pretty well, so I hope I don't have to get into it anytime soon. I have no idea of the history of the engine. It could very well have already had the timing gear changed - I'm sure I'll find out someday.
Another question. When I use a strobe light to try to set the timing, I can't make the pointer show up in the window - that is and still have it run. With the engine not running, when I turn the engine so that I can see the pointer in the window, the rotor is pointing to number 2 or number 5. Any idea what's up with that?
Doug 54 Chevy 3100
