Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (1955 1 Series, Otto Skorzeny), 103 guests, and 5 robots.
Topics128,283
Posts1,058,505
Members48,490
Moderated
Moderated
I'm attempting to rebuild an original AC 1523089 fuel pump from my 1950 3100 with a 216. After taking it apart and obtaining what is supposed to be a rebuild kit, I'm finding some different parts. I'm sure there are variations on these. It is not a combo fuel/vacuum pump, but it does have an extra spring and parts on the underside of the diaphragm. Those parts (pictured below) and in order (starting from the underside of the diaphragm and working towards the bottom of the pump body) include:
- A small spring (not the large spring, although it does have that one as well
- A flat bottomed metal cup
- two flat rubber disks
- a flat, slotted metal cupped disk with a slotted hole, which when placed over the shaft and turned will lock together the loaded assembly of these parts.
In addition, the rebuild kit also came with a rubber cup (also pictured) which my pump did not have. I am thinking that new rubber cup might replace the assembly above, but looking for advice/guidance here. Any one else seen this before who can provide some reassembly tips or if I just sourced the wrong kit? I can't seem to find kits with all of those components. Thanks is advance for any and all help!
Where did you get the rebuild kit? Then and Now says that their FPA-146 is what fits your fuel pump. FPA-146 kit I rebuilt my fuel pump with that kit and had no issues with getting it back together.
It could be that a different rebuild kit was installed in your pump previously.
But if you call Tom at Then and Now (781) 335-8860, he'll likely help you sort it out. Maybe send him pictures of your diaphragm assembly and the parts in question.
Rusty - From what I know, those rebuild kits cover multiple models, as shown in the FPA-146 kit link Kevin posted. Some use that seal in your third picture while other don't.
Here's a video I found that shows the rebuild without using that seal. Chevy '37 - '51, 2 Valve Mechanical Fuel Pump
~ Dan
1951 Chevy 3 window 3100
AD Addict & Tinkerer
Tom is only answering calls on Tuesdays and Thursdays.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks, Phil
I should have included this information I got from them back in April:
We are very shorthanded and only have designated telephone staff on Monday and Thursday, 9-3 pm EST. We do try to cover as many calls as we can the rest of the week .
Thank you,
Tom,
Then And Now Automotive
@3100RustyParts
If you want PM me, I can provide Tom's e-mail. I don't want to post it here in the forums, as I'm sure he's already getting enough spam.
I may have mistaken Tuesday for Monday. dang
Then and Now has several videos on YouTube showing how to rebuild a pump. You’ll have to go thru a few before you find something close but you’ll get the idea. Here is a link to get you started.
Phil
Project Journals
