| | | Forums66 Topics128,279 Posts1,058,593 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 284 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 284 | 1st question.Ok so I read up on an article from the 235 guy and it looks like I cannot run a 1959 848 head on a 1954 block? Or can I? 2nd question. On a 1959 235 with a 1959 848 head. If I run early rockers I need to restrict the oil per the 235 guy? I see he milled his own part. Sorry for all the questions just trying to get something built.
Shade Baby | | | | | Joined: Jun 2023 Posts: 284 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 284 | 1- Yes 1954 235 with a 1959 or 60 235 848 head and use the 1954 rockers and oil feed. Not sure why Patrick had me pinch off the oil dump for the 2003 build.
2- is still a question I need help with?
Shady | | | | | Joined: Feb 2004 Posts: 29,960 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,960 | Who is "235 Guy"? It sounds like he needs to do a little more research. With the right rocker arm/shaft assembly, an 848 head can be run on any 235/261 engine. Jerry
| | | | | Joined: Jun 2023 Posts: 284 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 284 | Thanks for all the help. I got from here.
Shsdy | | |
