Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Jon G, Dennys28, Uncles51, texas46), 113 guests, and 1 robot.
Topics128,279
Posts1,058,593
Members48,492
#1615154 11/10/2026 9:03 PM
1st question.Ok so I read up on an article from the 235 guy and it looks like I cannot run a 1959 848 head on a 1954 block? Or can I?
2nd question. On a 1959 235 with a 1959 848 head. If I run early rockers I need to restrict the oil per the 235 guy? I see he milled his own part.
Sorry for all the questions just trying to get something built.
Shade Baby
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
1- Yes 1954 235 with a 1959 or 60 235 848 head and use the 1954 rockers and oil feed. Not sure why Patrick had me pinch off the oil dump for the 2003 build.
2- is still a question I need help with?
Shady
"Back In Time"
Follow in the DITY
Who is "235 Guy"? It sounds like he needs to do a little more research. With the right rocker arm/shaft assembly, an 848 head can be run on any 235/261 engine.
Thanks for all the help. I got from here.
Shsdy
"Back In Time"
Follow in the DITY
