| | | Forums66 Topics128,278 Posts1,058,251 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 792 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 792 | Subject truck : ‘54 (series 1) 3100 Recently my drivers side window dropped down abruptly and it ain’t coming back up. The window components are original and heavily worn , so replacement seems in order rather than repair. I’ve read that some repros need tooling and adjustment to work properly , and I wish to avoid that. What is the best source for a window regulator for my truck? CK Addendum: Window regulators is one of those jobs I was hoping to avoid for the balance of my tenure. How difficult a job is it to replace the entire mechanism? | | | | | Joined: May 2015 Posts: 11,260 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,260 | MY guess is that the button on the end of the arm has slipped out of the channel on the bottom of the window. If you can still feel the regulator moving inside the door, then it may just need a new roller and rivet. LINK The original ones are some kind of fabric based material and disintegrate over the many years till all that's left is the rivet, which can slip out of the channel.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2020 Posts: 792 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 792 | Thanks for the tip on that component. I’ll open up that door in a few weeks when the truck goes into winter storage and check for that. Given the overall worn up condition of the original regulator , including rounded off grooves on crank handle post , I am still inclined to replace the whole smear. (there - I dated myself by using that last word) | | | | | Joined: Nov 2021 Posts: 1,439 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,439 | I got my replacment window regulators from Classic Parts. Nothing special about the source other than price when compared to the other typical sources.
I did end up getting new window handles from the same source because old handles and new regulators don't appear to play well together. | | | | | Joined: Mar 2010 Posts: 10,334 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,334 | Good plan Waveski. You are not old. Old people say, "Shmear."
| | | | | Joined: Nov 2020 Posts: 792 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 792 | Damm , got me on a technicality!
