Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (pauld, DennisM, Chev4t6, lumbersawyer, Phak1, J Lucas), 110 guests, and 0 robots.
Topics128,279
Posts1,058,593
Members48,492
#1615020 11/08/2026 9:47 PM
If you're trying to free up a rusty engine by soaking the cylinders with an acetone/ATF mixture, try adding a handful of dry ice pellets to the procedure. That 70 degrees below zero dry ice will shrink things down enough to help the penetrating solution do its job.
Makes sense!
