4 members (TUTS 59, Southerntruck, Otto Skorzeny, dunfire), 63 guests, and 1 robot.
Topics128,095
Posts1,056,067
Members48,433
#1614 01/24/2005 1:14 AM
I've been looking for a 60 or 61 hood to put on my 63 suburban for a long time. They're very hard to find in the Midwest partly because they had a rust problem. I finally found a good one on a 60 2ton. Will the hoods switch between the 1/2ton and the 2ton and if they will, what else do I need off the 2ton such as hood latch or hinges to make it work on the suburban? I'm pretty sure the doors and the cab interchange. Can anybody give me the scoop on the hood (no pun intended) Thanks
#1615 01/24/2005 3:56 AM
Junior Member
Junior Member
as far a I know the 2ton hood will fit fit the same as the 1/2 ton I used a 1 ton hood on my 1/2 ton and everything lined up alright good luck and keep on truckn
#1616 01/24/2005 5:13 AM
It will fit as long as the 2 ton is not a low cab foreward model. I would be sure and get the latch assembly too because there are some differences between year models. Also the lights in the 2 ton hoods were just park lights-the turn signals were mounted on the fenders. However you should be able to use the sockets and wiring from your 63 hood and use amber bulbs if the 60 hood has white lenses.
