8 members (TUTS 59, J Lucas, Bill Hanlon, GMCJammer51, NJC, Wayne67vert, 2 invisible), 76 guests, and 2 robots.
Topics128,263
Posts1,058,136
Members48,482
#1614943 11/07/2026 4:22 PM
Subject truck : ‘54 (series 1) 3100
Recently my drivers side window dropped down abruptly and it ain’t coming back up. The window components are original and heavily worn , so replacement seems in order rather than repair. I’ve read that some repros need tooling and adjustment to work properly , and I wish to avoid that. What is the best source for a window regulator for my truck?
CK
MY guess is that the button on the end of the arm has slipped out of the channel on the bottom of the window. If you can still feel the regulator moving inside the door, then it may just need a new roller and rivet. LINK The original ones are some kind of fabric based material and disintegrate over the many years till all that's left is the rivet, which can slip out of the channel.
Moderated by  ndkid275, Phak1
