5 members (ShopRag, Pinetree, dt235sd, klhansen, Southerntruck), 85 guests, and 4 robots.
Topics128,263
Posts1,058,133
Members48,482
#1614010 10/26/2026 1:22 PM
I am getting ready to put my truck away for the winter. It will be stored in a heated (45 degree) garage with no plans to drive it for the winter months.
My current plan is to fill the fuel tank with fresh fuel with a fuel stabilizer added then pull the fuel pump fuse and run until it runs the carburetor dry.
I do have it on a battery tender.
Any other recommendations would be appreciated.
1949/50 3600 Project
Follow in Project Journals
To deter critters from chewing up the interior and wiring, I put bars of Irish Spring soap under the seats, dryer sheets in the engine compartment, and stuff the exhaust pipe with steel wool ( don't forget to remove in the Spring).
Hank
I always change the oil and filter, then park it for the winter.
Brian
1955.2 3100 Truck
Cruiser - Here's a "Legacy Tech Tip" WINTER is coming! that has been around for a good long time. smile Something you can read to add to what folks these days are recommending. thumbs_up
~ Dan
1951 Chevy 3 window 3100
Thanks for the input.
Engine oil was recently changed and coolant was new in the spring.
There's still a chance that I will be pulling the engine this winter (see Hi Perf thread) so not planning to go too crazy.
WICruiser #1614406 10/31/2026 10:25 AM
7
7 Offline
WICruiser, when you have the fuel stabilizer mixed well with the tankfull of gas, run the truck long enough to ensure the stabilized fuel has made its way through the entire fuel system, if the gas that is left in the carburetor has no stabilizer in it, it will start to evaporate and leave varnish behind.
WICruiser #1614408 10/31/2026 11:53 AM
I installed the stabilizer when I filled the tank and then drove it 5 miles home so I believe it should be good.
Regardless if pull the engine, I will be pulling the carburetor to inspect the intake manifold and make sure the drain any residual fuel that may be there.
7
7 Offline
Sounds like you have it covered.
? Offline
I don’t really winterize the truck. I set the truck up on jack stands. Stabilizer for the fuel. Every other week I start it, a run through the gears then a check of the fluids, look for leaks. Also recommend using a electronic mouse blocker for the garage and the truck. I have never had an issue using this routine.
WICruiser #1614910 11/06/2026 10:32 PM
7
7 Offline
I like to drive, I like to drive trucks, I like to drive my trucks in the winter, the '57 eats enough gas that it doesn't sit long in the tank. The Vette and bikes get Sta-Bil.
