7 members (Pinetree, Otto Skorzeny, Deegs53, kurbside bolter, Maybellene, 49oneton, 1 invisible),
138
Mod | | | Forums66 Topics128,258 Posts1,058,083 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2026 Posts: 15 'Bolter | | 'Bolter Joined: Jul 2026 Posts: 15 | Code: 357496900312040896
Expires 12/04/26
5% off | | | | | Joined: Sep 2009 Posts: 6,150 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,150 | Thanks for sharing that ShopRag.  Will leave it up until it's expired, then remove as it won't be valid afterwards. Maybe folks that use it can share info on some of the deals they found?
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | They barely carry anything for my '65 anymore. I don't know about other generations. | | | | | Joined: May 2015 Posts: 11,253 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,253 | I've bought quite a few things for my '51, from Rockauto including rocker panels, although I don't see that kind of stuff lately. They have most engine parts and gaskets, while the local parts houses don't stock pan gaskets now. But paying shipping is a bummer, especially for one or two items and when each item comes from a different warehouse, it's even crazier, you get to pay twice.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
