8 members (pvfjr, crenwelge, Gdads51, Mike Burns, rfs56trk, ndkid275, Goach2, 1 invisible), 158 guests, and 6 robots.
Topics128,241
Posts1,057,871
Members48,477
#1613718 10/21/2026 2:36 PM
G Online: Content
Hello all,
I'm at the end of a 12v conversion on my 3600 and I was wondering if anyone had a wiring diagram that included the heater/defrost motors in it? I have two variable switches and two motors in the unit itself. I haven't added in in-line resistors yet and that was next on my list, however the new 12v mechanical flasher socket seems to have a loose wire. When I wiggle it with the engine running, both heater motors turn on. This seems impossible since both switches for them are in the 'off' position, but that's what's happening. I just want to chase the heater wires back to make sure they are correct. I didn't have any issues like this with 6v, so this seems pretty odd to me.
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
The '48/'49 Chevy truck wiring diagram I just pulled from The Old Car Manual Project doesn't show the heater. Must have been an option.
Because of the "2 fan motor" heater/defroster you have I'm guessing your 12 volt conversion wiring system is aftermarket. Don't you have a diagram?
G Online: Content
This might be a Canadian thing or dealer installed. I guess there won't be any diagrams. Would it be best to wire this to the aux connector on the light switch?
More images
That's what I would do. Tie the feed for the two switches to the aux terminal of the ignition switch.
Two 12v fan motors will pull quite a bit of power, our school bus fleet at work runs 20 amp fuses for each two motor heater using 14 gauge wire. The wires are quite long so the big wire is needed. They use every bit of the 20 amp fuse, just a little corrosion at the connection will knock out a fuse or trip the circuit breakers. These are likely bigger motors than yours.
If you will be running both motors at the same time, I would use a relay with a heavy wire off the amp gauge as a relay feed, then use the ignition source for the switch to turn on the relay.
Powering off the light switch could leave you in the dark if running lights, defrost, and heat all at once. The light switch should have a built in circuit breaker designed for the lighting load, adding in two motors could put the amp load too high for the breaker.
G Online: Content
I don't drive in winter and have never opened the valves to allow coolant to flow into the heater core, so these are more for show and the defrost is likely the only one I would ever use. That being said, I never had an issue with them before the conversion. The blue-wire from the three prong flasher socket seems to be tripping the fans to come on. Any idea how this could happen?
More images
Sounds like you have a short between circuits (insulation gone from both wires and the copper touching.) A rewire should fix that.
Joe's idea of using a relay to isolate the heavy load from the ignition switch is a good one. Pretty easy to do. If needed you could run a separate heavy gauge wire from the Starter terminal (with a fuse) to the relay, but the Amp gauge as a source should work OK. If you're still running the 6V wiring, the gauge should be good, as using 12V on the same load originally run on 6V only draws half the amps.
Seeing as how a 48 Chevy truck didn't leave the factory with turn signals, it will be hard to diagnose this problem without an up to date wiring diagram.
G Online: Content
Well, the heater fans have old cloth covered wiring and I'd be surprised if they weren't original or a dealer add-on. The fans are both wired to the ignition switch. The 7 wire signal switch seems to be wired correctly, with black/blue going to the flasher relay. Power to the relay from the aux on headlight switch. Problem is all terminals on the flasher have 12v (or about 9 when it lights the signal lights back and front. ). But no flashing. It was working previously for a bit when running but now the relay doesn't move. It did say it was for LEDs but maybe that wasn't correct. Also, the little indicator bulb in the signal housing doesn't seem to get power either, which is the blue wire. I'll try picking up another flasher, but I don't know where to go from there if it gives the same result.
More images
Some of the LED specific 3 prong flashers have a separate ground wire for the electronics inside the can. Any chance yours is that way?
If you are reading 9 volts on the wire between the flasher and power with a regular (not electronic) flasher you'll never get enough current thru the bi-metallic strip to heat it up and make the flasher work. As a troubleshooting step, disconnect the flasher power wire from the headlight switch and hook it directly to the ammeter + side to see if the flashers work there
G Online: Content
Well, I have seen the flashers with the ground wire and I assume those are for low-voltage LEDs. I just swapped out my rears for incandescent and it flashes as it should. The indicator light in the signal switch still doesn't work though but I've gone this long without it, so I guess I'll live. For the heater fans, it looks like it was a loose wire causing them to come on. I still have to grab 12v bulbs as they are illuminated switches and put the resistors inline. Since I have two fans, I'll probably look to mount the resistors to a piece of aluminum or something and hand under the dash.
More images
Better yet, mount the resistors inside the air ducts of the heater to keep them cool. All muti-speed resistors packs are mounted in the air stream as way to cool them, might as well follow them.
If you want LED tail lights / brake lights, install a 1157 bulb and socket up in the frame rail out of the weather and out of site to create a load on the flasher, the LED's will then work as they should. #2357 is a incandescence bulb with the same tail tail light as a 1157, but a brighter brake light. Paint the inside of the tail light white and do away with the LED's. #2057 is a Halogen version of the 1157, they get way hot, so you need glass lens. They will melt plastic.
G Online: Content
That's a good idea for mounting the resistors, might as well use the heat they produce. My tail lights are all LED, just the signals in the housing are incandescent. I can live with that. I just took it out for it's first drive after the 12v conversion and I noticed two things. My gas gauge is on empty (not related to pump prices ;)) Did I get the runtz in incorrectly? Also, my Ammeter never actually goes to the charge side, even on the highway. Is this something I need to adjust in the voltage regulator?
More images
The amp meter should be right at zero or very slightly on the + side. The alternator is putting out just what is being used, no more or no less, so the gauge stay centered. Mine will show plus charge for a short while right after cranking it after setting for a week or so, after that it's centered.
Gas gauge needs to have 6 volts going into it, and the fuel sender needs a really good ground wire right to the sender. The tank is not a good ground. I ran my ground wire all the way back to my main ground stud I installed when making my wire harness. Fact each light is grounded that way also, I don't like chasing ground issues! Use a jumper wire from sender to frame ground or to the battery post as a test, if it still doesn't work, check input voltage at the gauge.
G Online: Content
Thanks, the gauge was working just fine before the runtz resistor. I think since it's on empty it might just be a bad ground, so I'll check that out first.
More images
Assuming the gauge is getting the proper voltage from the Runtz, an "always empty" indication is caused by the other wire that connects to the sending unit on the gauge being at ground all the time.
Troubleshooting is fairly simple. With the key on, half a tank or so of gas and the gauge showing empty:
Remove the wire from the center of the gas tank sending unit. If the gauge now reads full, the sending unit in the gas tank is bad.
If the gauge still reads empty...
Remove the wire from the back of the gauge that the Runtz is not attached to. If the gauge now reads full the wire between the gauge and the sending unit is touching ground somewhere.
AD Addict & Tinkerer
Should Bill’s quick troubleshooting tip not work, there is a troubleshooting “Tech Tip” in the Electrical Forum that may help here.
Phil
Project Journals
Stovebolt Gallery Forum
G Online: Content
Ok, so I finally got out to do some testing.
When 12v is measured at the runtz input, I get 0v at the output. I tested the ground wire and it's good. Does this signal a bad runtz?
More images
G Online: Content
So, another question while I ponder the runtz; my new battery keeps draining down on its own, no key, no lights left on. Could this be a problem with the regulator?
More images
You have a parasitic electrical drain (unless the battery is a piece of junk , which is relatively common these days) Does the battery stay fully charged when disconnected from the vehicle?
You're going to have to test each circuit but the voltage regulator is a likely suspect so start there.
1. Attach a multi-meter set to Amps with the red wire in the high amp jack.
2. Set the dial to DC amps.
3. Disconnect the negative battery cable from the battery and connect the test leads of your meter to the battery terminal and the negative cable.
4. The meter should read 0.00 amps
5. If your meter shows any amp reading, you have a parasitic draw.
6. Disconnect the BATT wire on the regulator while watching your multi meter.
7. If the reading drops to zero, the cutout relay contacts on the regulator are likely stuck together causing a constant draw.
If the voltage regulator is not the problem, continue testing the other circuits (ignition, lights, heater, horn, etc) on the truck in a similar manner.
1. Disconnect main wire on the back of the ignition switch.
2. If the reading drops to zero, replace your switch.
Do the same thing with the fuses on the firewall, etc.
1950 Chevrolet 3100 (Ol' Roy)
G Online: Content
So, I tried the suggestions provided by Otto (which are very helpful). On the neg terminal, I get no flow. Turn on cab light and I can see it moving, take back off and nothing. So it's either so low it doesn't show on the gauge or it's the battery? The battery is new, I had to charge it when I first brought it home. I have one of those simple resistance battery testers and it says it's close to the yellow area. I brought it back to the store and they tested it and said it's fine. Theirs was a fancy digital meter, so it has to be correct, right? I charged it again and have it sitting on my bench. I will see if it drains on it's own. After that, I'm not sure where to go after that...
More images
Find a shop to load test the battery, have them do the initial load test, then wait a couple minutes for it stabilize and do a second test. The digital meters are OK, but a heavy load test will find a bad battery every time. You should not need to charge a battery off the shelf.
